I have been using my printer for over a year now. Today I loaded green filament (not a new roll), printed a Yoda bust and then couldn’t print any other designs that I had successfully printed before. I had the same problem with red yesterday. When it says it is printing but nothing comes out I tried loading the filament to see if there was a clog and it came out in a nice steady stream. Tried to print and it didn’t. Any ideas?
First, I want an invisibility cloak printed out of your invisible filament. Second, can you tell us what type of printer you have and what type of extruder + hotend as that will enable those with experience on those setups to give more specific guidance. Also what type of material? PLA, ABS, other?
Sorry, I solved the problem before I could print the cloak. Operator error. I had switched settings to have the extruder heat to 60 degrees for a flexible filament experiment that didn’t work. I forgot to switch it back when I sliced the next files. All is better now!
+1 on that invisible cloak though!
I’ve heard that @ColorFabb is working on it :wink:
