Hi i wonder if the list of printers we can add are public somewhere ?
since we cant get printers added that we have build and tested ourselfes, the only way is to add one with same specs and build volume
i need a printer with 500x500x500 build volume that is allready in the database
Hi Bo,
Maddie here from 3D Hubs. While I don’t believe there is any way for our users to see all the available printers we have in our system, we do offer an option called “Other Cartesian” for custom machines that you can select, and we happen to have one that’s exactly your build volume as well.
I hope this helps!
Best,
Maddie - 3D Hubs
it does help
thou it must be a new option since when i made my custom mendel90 it was not possible
but at that time the original prusa i3 had the same build volume so i picked that. of course i made sure to check that the print quality also matched
are there an option to rename an excisting printer?
Hi Bo,
I don’t think there’s a way to rename an existing printer, unfortunately I think you’ll have to reproduce all your pricing settings under a new one.
Best,
Maddie - 3D Hubs
