I’ve been trying to print the shelf of this item but every time no matter the infill or speed it prints tojust about layer 12 and then it stops extruding and the fil. starts grinding and the prints to mid air. All the drawers and other prints work just fine. Any suggestions ?
jfield
Temp too low, too much retraction?
Run it through a checker to see that the STL is ok.
I thought the same but it’s the exact same spot on just this stl. I’ve used s3d and cura temp is 200 (pla) and all other prints are good. It gets 95 percent of the base and stops extruding/starts grinding it so never starts on the walls.
