That I have never seen. I would do a search to see if there is anyway to modify the starting gcode for maker ware. Sorry I can’t help you here.
ok i will look around and see what i can find.
Thanks so much for everything Eduardo you have been great and i really appreciate it.
Cheers
MPRU
24
iv got the same problem been looking at this proftweaks do you have any links for how to use it ?
The makerbot website shows what the parameters mean. It’s not perfect but it helps. There is no clear cut way, you’re gonna have to fiddle with it and tune it for the printer and material. One of the main things that helps is the extrusion multiplier. Find in thingiverse the nozzle calibration for ctc and that tells you how calibrate it in proftweak.
iCloud
26
No this is normal it’s part of the new makerware update i believe for the bed to go down and back up
Same problem here, i now use Makerware and Astroprint to control the printer and no longer have any issues and don’t have to bother with usb cable or sd cards, you would need a Raspberry Pi 2 or 3 though for Astroprint.
