Amneh94
how can i print handrail without any distortion Even Though i decrease the temperature and the speed of machine
the machine is Ultimaker 2 Extended
MVlad
Print horizontally. This would increase the quality and also lower the print time.
Where you have corners in your handrail model, simply split into 2 parts that you print separatelly and horizontally and then assemble / glue into final shape.
TypeR
Like said before, you print this horizontally.
Always try to optimize the orientation of your print for best quality if possible.
Amneh94
I tried , nothing change same bad quality
TypeR
6
Well, ok.
It would be nice if we knew a bit more about the object and the print settings you are using.
If the print is actually very small, I would suggest you try printing 2-3 of them at the same time.
If cooling is our issue, printing multiple objects gives the material more time to cool.
