Hi guys, I need your help. I just designed two items for my light camera JIB project but I would like to test if they fit on in another and if le dimensions are good by simulating the lock mouvement (basically it’s just a slide and half a revolution). Could you tell me which soft can do that ? It’s really just to check if everything is well calibrated, no stress test or weakness research. Thanks !
Heya,
I’m a little unclear on what you are trying to do. If you want to test the fit before fully printing, you can always pause the print a few layers in and check. You can always measure the dimensions of the STL file you designed and match it with your camera. Do you have some pictures on what you are trying to do?
Alex
