I have ord bot, got it from Punchtech several years ago, had it up an running. He no longer is offering any support. Need to load the software on a new computer. So I’m starting over, need to get the files set up correctly on the new machine. Thanks for any help.
Tom
The ord bot is basically a riprap type machine. Go to Download Software - Repetier Software and get repetier-host. Install it. Go into the printer setup and make changes to the default setup files for the size of the print area. Plug in your USB cable and setup the connection. Should work to get you started.
If you have any specific questions goto http://www.buildlog.net/wiki/doku.php?id=ord\_bot:the\_ord\_bot . Seems to have some good information to help.
