maxdor
I installed the mosfet for the extra cooling fan and tested it by Manual Mode in S3D and over the Terminal in OctoPi with the code’s: m106 (on) m107 (off) m126 (on) and m127 (off). It worked fine.
Then I create a .gcode file with S3D and then print it with OctoPi. In S3D I have set under Cooling settings, that the fan will start from the 1st layer with 100%.
But it won’t start.
Are there some more settings I have to set in S3D or octoPi to get the fan to work while printing?
Thanks for ur help!
maxdor
I Printed a .x3g file from S3D directly from SD Card. There is the same problem with the fan. So OctoPi can’t be the problem.
The Printer is a Replicator 1 Dual with Sailfish 7.7.
