After creating parts in solid works using inches as the unit Measure, and then when adding this part into Netfabb The part shows up being 25.4 times larger than it should be. Obviously something to do with inches/metric.
I don’t think the problem has to do with SolidWorks since I have sent the same parts to other programs and printed them.
I have looked at all the menu options on NetFabb but cannot seem to find the right button to push.
The first time I used Netfabb I had no problem properly loading SolidWorks ark files. So I don’t know what has changed anybody have any ideas?
Thanks, Chuck
Netfabb thinks it is in mm. Try a google search on how to change the units type.
Thanks, you are right and I found out how to change the units and everything is fine now.
