I hope you can help me In the past i have used acetone afterwords to make my prints waterproof but that also ruins the color of my pla . Is there any kind of spray paint i can use to relible make my prints hold water?
Best Buynba2k - Nba live mobile coins so cheap and safe!
Can you post a picture of the print and the issue area because the print should be watertight hence making it able to hold water, may be an issue with the model. Depending on what you are housing in the pla and if you are planning on consuming from it there are various thing you can use such as epoxy, or even just clear coat… Just depends what it will be used for
