Hi all,
My name is stefan, im from the netherlands.
Im working on a project for my playstation 4 controller buttons.
i bought some epoxy and rubber to make a mold, but i dont like it and its not fitting perfect.
Maby there is someone that can make me a 3d for some molds. Here a picture about what im creating.
Henneo
Hi Stefan,
Are you looking for someone to create the 3d model for you? or would you like to have the parts printed? You do have you own 3d printer?
Kind regards,
Hennie
Hi hennie,
I just need a 3D model, just for making the parts i need. i want to make more of that parts i need.
No i dont have a 3d printer, im just looking for someone that can help me with this
It needs to be something like this.
Greetings
Stefan
I assume you want to model the buttons, print the buttons, use the printed buttons as pattern to make a rubber mold, then use the rubber mold to make final part using epoxy?
I’m sure you are aware that 3D printed parts have layer marking and other surface defects on them, meaning when you make rubber mold based on 3D printed object, the mold itself will have such defects. I have done this in the past - 3D print, surface treatment with acetone vapour, still having surface defects. Best is to find a CNC machinist (3DHubs starting to do CNC, look around) to make the pattern, then you can use it to make rubber mold and your end product will have much better appearance.
Liang
