Does anyone have any software settings that they use for simplify3d for monoprice. Also for some reason it is warping my material when I am printing any suggestions? Thanks, much appreciated. It wasn’t warping before this new software.
Have you tried cura 3d? Pop in your printer bed dimensions, the default settings should work OK for you.
is this for simplify3d, also do you pay for that software?
So no it’s not for simplify3d. Cura is free.
Can you send me the download link. Thanks. Also does cura allow you to print the support material as pva
http://bfy.tw/4QTN. Material settings are customizable, the software doesn’t limit your options. SImplify 3D works great with the monoprice btw, you just need to calibrate the settings.
Is this PLA or ABS?
You can download my Monoprice Simplified 3d Profile here:
I use PLA
But why would he go to cura when he has S3D? S3D is far better
I use pla as well with no heated plate. Only blue tape. Where would I paste this code? Do u mind sending me a video tutorial. Thanks
email is gevoaelian@gmail.com
I really appreciate the help. I have been struggling with this great software and am regretting purchasing it now.
How do I import my old profiles?
To import a previous profile into the software, select File > Import FFF Profile from the main menu bar. Feel free to choose multiple files if you wish to import more than one .fff file at a time. After importing, the profiles will be available from the FFF Settings profile drop down list. It is also useful to know that when opening previous 2.x versions of the software, your settings and profiles remain untouched. So if you forgot to export a profile that you needed, you can easily open a previous version of the software and export the settings that you needed. let me know if you do need more help though!
