Falc1
Hi all,
Just joined your site after doing a lot of research on it looking for a solution to my problem. I am hoping someone can help but my guess is I will need to return this printer. Again, the first one I got had a bad motor. Just got the new one and when I hit Home All, the Print head is where it is supposed to be, front left corner. But the bed moves all the way to the back. Meaning that the print head is at home postilion but not over the bed. I feel like the bed was installed backwards or wired in reverse. Thoughts? Going to be super annoyed if I have to return another one. I purchased it a month ago now and haven’t got use it.
Quite possible the stepper motor for the Y axis is plugged in backward. You should be
able to reverse the direction via a gcode command.
