I was printing prints all day yesterday, then today upon pressing start print the heating elements will start to heat and go way past where I set them. Then I press cancel print, and it starts printing normally (after getting to the right heat settings). If I hit cancel again then it will lift about an inch from the bed and keep printing, just spewing filament everywhere… turning off the machine is the only way to stop it at this point. Also ever since i downloaded Cura off the Micro SD I have been experiencing full system failures on my pc.
Please Help, sincerely
Rob G.
Very strange. Maybe a controller board gone nuts? How long have you had it? You might be able to receive either a replacement unit, or a replacement controller board, if that is the problem.
You should head over to the Monoprice Mini Facebook group. (There are several, look for the one with over
eight thousand members.) There are some real experts there.
