wesbob
I’ve had my MM v2 for a couple days, had success with the gcodes on the flash drive but running into issues when printing larger items. For some reason one end of the print does not stayed adhered to the plate. I’m novice with 3d printing but am an engineer and a quick learner. I’ve played with adjusting the settings in Cura to slow down the printing (solved issues of nothing sticking at the beginning) but now part way through one side pops up.
Is this a known issue with this printer and/or is this possible to fix by adjusting the temperature of the plate or another sertting?
I am also a new user - I ‘upped’ the temperature of the plate to 60 or even 62 degrees that helped somewhat - but I’m still having the same issue as you.
I haven’t tried slowing down the printing -
right now the printer is out of commission because a raft came loose (while I was out of the room) and the entire extruder got covered in filament… completely covering the thermistor cable. I couldn’t clean off the failed print without breaking the cable. Once I get the printer back into commission (I believe I actually have a spare part!) - I’ll try slowing the print down and see if that helps - I believe I’m still at the default speed. I’ll let you know how it goes.
wesbob
switching from a brimm plate to a raft helper a ton with my adhesion fwiw.
