Can anyone tell me what the MINIMUM vref voltage for the DRV8825 driver is. In other words, what is the smallest motor it can power?
Nevermind, I think I found it on the datasheet;
Description MIN MAX UNIT
Continuous motor drive output current(4) 0 2.5 Amp
Notes
Operational at VREF between 0 to 1 V, but accuracy is degraded.
If you discipline yourself as calendar , june 2017 Printable calendar one day your personality will get success. may 2017 printable calendar A calendar store your past, witness for of today and, it give plan for tomorrow…… Attendance Sheet Template thanku
What is normal pressure wrist blood pressure monitor The heart beat (contraction) begins when an electrical impulse from the sinoatrial node (also called the SA node or sinus node) moves through it. The SA node is sometimes referred to as the heart’s “natural pacemaker” because it initiates impulses for the heartbeat. Sign of high blood pressure Blood pressure measurement thanku
