Hello, how can I connect with some hub for discussion? I also tried to connect via 3D print service, but hubs without feedback are not visible. Thank you!
Hi @Flash_Dreamer, you can go to our ‘Start a 3D Print’ page and select your location. This will show you hubs in your local area. Select a hub and after the pop-up, select ‘View Hub’ underneath their profile on the left. You can then select ‘Contact this Hub’ to start a conversation and enquire about your needs.
I’ve done a search for you based in Varna - I hope this helps and good luck!
