What are the maximum that can be printed by your hub? I am looking to print something that is slightly smaller than an 8.5" x 11" sheet of paper.
Hello We can print objects up to 11.2" x 10.6" x 9.06" And the resolution up to 70 microns. Sunshine prototyping’s hub
Hello we can print up to 10 in*9 in*8 in. Please use my hub.
Hi Joe,
I can print a max of 16"x16"x12 up to 80 microns of resolution. I’m just getting my hub started and I would be happy to help you print your file.
Best,
Aaron
Hey, we can do 12in by 12in by 13in. Send me a message if I can help with anything.
Hi Joe,
At the Micro Factory we can handle 16"x16"x18" build volume. 2 other machines that can handle 10"x18"x8.5". So if you many parts quickly TMF has the bandwidth to handle many prints at once.
-John
i can print up to 10" length x 10" width x 10" height. thx.
I can do 6"x6"x10" at 50microns, thought somethings that large at high resolution will take days to print.
(XYZ)6” x 6” x 4” (152.4mm x 152.4mm x 101.6mm)
I can do 18x18x14" on one printer, and 12" x12" x16 on another.
I am able to print 5.9 inch cubed, however, if the part can do it, it is possible to print them in sections and then adhere them together after the print
I can print 10" X 10" with 12" in the Z axis. All in a fully heated build envelope so there is no warping.
12x12x12
