I needed a cool way to hold the Marvin samples. This is the result.
Can I suggest printing a larger Marvin like you have, only with a series of pores across it’s body big enough for both feet of a smaller Marlin to click into, allowing for a ton of them to be coating the larger Marvin?
I’m sure its very doable. I guess I could write some scad code to auto cut the holes. I’ve seen lots of vases with minimized material but have no idea what software they use. I think the detail of the large marvin would get covered up.
Oh and btw, Marvin is unsanded and painted black for demonstration purposes. It shows the customer what happens if a little bit of elbow grease is not applied.
Here is the the file. This guy is hollow with a bowl on top. Meshmixer supports added but the center is not supported well. So, Make sure you add a few extra supports in the center on the inside just under the bowl.
large marvin.obj (49.3 MB)
Thanks for the awesome share, Craig! We’ve already started printing one on our in-house Big Builder
Cool… Be sure to post a picture
If all goes well, tomorrow morning (Amsterdam time) we’ll see the results
