Dear community, I need your help in getting better print results when I print my Marvin in 0.06mm. I tried to do many experiments starting with 0.1mm layer height and then going to 0.06mm. I have tried everything from temperature, speed and retraction (but feel free to mention again).
As you can see in the picture the 0.1mm print seems to be more clear compared to 0.06mm. So what is wrong with my parameters in Cura for 0.06mm? The issue appears at the right ear of marvin and at the bottom of the helmet (something like ghost or vibration effect like waves).
I would appreciate every help.
Most likely belt tension problem, just loosen the screws for you X/Y motors, pull the motors and tighten the screws.
I tried to re-tighten my belts and added idlers with teeth for more precision. I will write if it get’s better. Also the marks seem to be always at the same spot. Could this happen due to more cooling (than what is needed), or cooling angle?
Thank you for your reply :slight_smile:
