Hi folks I have a problem. I have 3 mega2560 ramps1.4 And cannot run marlin but can run repetier. Anyone knows why ?
what error are you getting when you upload it using arduino?
Also what version of marlin are you trying to use?
HI
No eror with the arduino IDE when uploading.
i can not connect to pronterface or repetier host
I get a no signal force start error
hey, I had a similar issue. Try to remove all the stepper drivers, and any other connected stuff. When you have only the ramps connected to the arduino board, try to connect to it via repetierhost. Another way is to see what happens is opening the serial port in arduino ide, and check what it writes there… Hope this helps, Cheers
