WDA66
I have a Cubic Kossel and want to increase the print area from its current 135mm (Should be 180mm but not very well designed by Cubic) to 250mm.
Do I just need to buy some OpenBeam and move the z beam further out and make longer support arms for the print head?
mx20100
Hey WDA66, How are you?
You will also probably need to edit the software limit. If any.
Good luck!
Best,
Max Moors
WDA66
Thanks for the reply. I have worked out how to alter the limits in the firmware. If all goes well I plan on building another with a 1.5m bed with a Z height of 2m, and a massive 5mm nozzle.
mx20100
No problem! Wow that is goinh to be a massive printer! I’m curious on how it turns out.
Best, Max Moors
