I’m having trouble with Makerbot version 3.8.0.377
I want to print an object using the left extruder but no matter what I do it tries to make it print with the right.
I select the object and designate it to be printed with the left extruder which highlights the object in red. I then preview it and even though it is still red the software talks about a right material estimate and when I export the print file and go to print it tries to use the right extruder.
I’ve tried everything I can think of without success. I’ve been happily printing all day and then this has suddenly happened for no apparent reason.
I only use the left extruder as the right one is broken.
If anyone has any tips for me I would be very grateful as I’m at my wits end.
Many Thanks.
I’m having similar issues.
Everything works fine using the right extruder, but if I try to print with two materials or using only the left extruder it won’t work. The printer heats up the right extruder, never the left, and extrudes an initial line.
I found that using the selecting one of the standard presets and restoring defaults seems to work but whenever I add a new setting or duplicate one of the default presets this issues occurs.
I’ve modified my printer to have a cooling fan for printing in PLA so I need to have a custom setting and edit the text file directly in order to use the fan.
Is there an archive of older versions of Makerbot desktop so I can test this with an older version?
Any suggestions or help would be very appreciated.
I have the same issue. Worked ok in 3.5, but updated to 3.8, and left extruder won’t work on my Replicator. Have you tried updating the printer’s firmware? I still have to try it when I get the chance.
I have been pulling my hair out over this same problem with my company’s Replicator 2X. I had created a custom preset for PLA in the left nozzle and couldn’t figure out why it kept trying to preheat the right nozzle instead. After reading what Tantor said below, I deleted my preset and edited one of the stock presets for PLA. Boom. Printing from the left extruder in PLA achieved. I too would like to get access to archival versions of firmware as well as MakerWare to work around this problem. In the meantime, I’ll avoid creating my own presets.
Exactly the same issue, and there are other posts with this in, it seems Makerbot doesn’t want to fix this!
