Hi!
After I my nossle got clogged. I decides to try to unscrew the nossle.
The thing is the nossle snapped off. So half of it is stuck in the hotend.
I need to buy a new hotend but i cant find one.
Do i have to buy a Makerbot round shaped hotend? Or can i use any hotend. They usually square ones?
Thank for the help.
Joakim Åhl
You may call the Makerbot support by e-mail or by phone: MakerBot CloudPrint™
They will send you a new hotend. Probably I can give you some ideas how to fix it if you post some pictures.
Lukas
here are some picture.Not the best. But maybe show more what i mean.
ok, your nozzle is broken. The easiest way is to call the Makerbot support and ask there for a new hot end. Probalby they send it for free, but shipping cost to europe are insane. Makerbot anywere just sell the whole hot end, you can’t just buy a new nozzle there. Try to remove the broken nozzle part form your hotend ( like this Extract a Broken Screw (DIY)). If it works you just have to buy a new nozzle. I think a 0.4 mm (just if you have a replicator 2x) nozzle from a other distributor should also work. Ther is also a shop which sales replacement parts for makerbot products, but I don’t think that it is cheaper if you buy a new hot end there: http://www.robotshop.com/en/makerbot-replicator-2x-parts.html
You should be able to buy a tool to remove this, you will need a broken bolt remover and you will need to disassemble the hot end. Next time do it when its really hot.
