Title says it. Print head won’t return to home position. It started after I calibrated the machine. Anyone experienced this or lend some insight on how to correct the issue or reset the printer?
look like end stop. can you make move (by control) in all the ways (±X, ±Y, ±Z)? probably one end stop are triggered.
I dont think that the zortrax has an option to move the print head on any access via control module. If that is an option, it is well hidden. I can re home the head manually after each print no problem though.
ROXG
Wohlen it happe de to me I recalibrated the platform and everything Wars ok after Thais operation.
do you try a host software to control via USB, like repetier-host or MatterControl?
