I have printed many things on my Zortrax m200. When the print is almost done there is a short beep then another short beep after it is done. My problem is when I turn the printer on it makes the same beep noise but it’s not a short beep. It does not stop. Anybody else have this problem? Any ideas on how to make it stop.
Check all wire connections it could be an error message.
Try updating a firmware to the latest version: Firmware - Zortrax Just save it on SD card and turn Zortrax on while inserted.
There is buzzer option in Settings tab where you can switch it off.
Hope it will help!
3DMuse
Hello @thebeastgoeson,
I get this beep when my buildplate connectors are not connected. The screen should show an error and a brief description on what it is. If it is blank or shows no error then maybe try reinstalling the firmware on the printer.
Regards,
James
