Beginner - Looking to make props (Helmets, swords) and models. Would like a decent sized print area to reduce the need to join various prints. Any Advice on a good printer? Of various prices. Looking to be using this constantly. With a heated base included would be good as well.
Examples of big prints you have done on your own printer would be nice to have, if your pitching me a printer you have used.
Price range from £400-£1000 some slightly over will be acceptable.
Thanks!
I’d recommend the lulzbot printers, the newest and largest version TAZ 5 is too expensive, so you can go with the limited (some features missing) KITTAZ which has to be assembled.
Alternatively a little smaller but still decent and a real workhorse would be the TAZ mini.
Those printers get used by James Bruton, a youtuber, that 3d prints life-size cosplays, like an Alien Xenomorph suit, Iron Man Hulkbuster, R2D2 and BB8.
Here’s his youtube channel: https://www.youtube.com/user/jamesbruton
There’s barely a large printer for that pricing, because larger build volume needs larger mechanics (rods, bearings, stronger motors etc.) the price increases exponentially for each cm of build area.
Alternatively the Ultimaker 2 or Prusa i3 (hephestos) are go-to printers for beginners as they have an enormously large community, which provides improovements and help for you. I’d recommend to upgrade your printer with an e3d volcano, it’s like a normal hot-end (the part where the material gets molten and pushed out of a small hole). But instead of normal nozzle diameters, like 0,4mm the volcano can have nozzle sizes up to 1,2mm.
This increases the possible maximum layer height and can speed up your printing by a factor of 10 or more. You trade resolution for speed, but as you said, the printer runs all day long, so you might want to make this upgrade.
Parts printed with larger layers are stronger and the surface can easily be smoothed with filler paste.
Here are links for reference:
lulzbot TAZ5
https://www.lulzbot.com/products/lulzbot-taz-5-3d-printer
lulzbot KITTAZ
<didn’t find it on lulzbot.com, look for it on amazon etc.>
lulzbot TAZ mini
https://www.lulzbot.com/products/lulzbot-mini-3d-printer
ultimaker
prusa i3 hephestos
http://colorfabb.com/kit-prusa-i3-hephestos
e3d volcano (v6)
http://e3d-online.com/Volcano
Marius Breuer
@Shibby90441, make sure to check out our Best printers guide :slight_smile: It can also help you out : Best 3D Printer Guide 2023 | Hubs
Cheers :wink:
Have you seen the Duplicator Prusa i3 it looks really good for £300. With a 20cm^3 build volume and 100 micron layer height. I don’t personally have experience with it but I do with the Duplicator 4x and they’re great printers for the price. To be honest I think the i3 is better even though it’s cheaper.
i think you should get a Flashforge® Dreamer 3D Printer,Dremel Idea Builder 3D Printer, Flashforge creator pro
good 3d printer all around 799-860 :slight_smile:
I hope it helps you :slight_smile:
