Thanks Scott…
Are you involved with evok3d? I just checked the website… is it the UP +2 that you are recommending?
http://www.evok3d.com.au/Up\_Plus\_2\_personal\_and\_professional\_3d\_printer\_p/upp003.htm
Regards,
B
Thanks Alex, I’ll take your advise on board…
Much appreciated,
Regards,
B
Thanks Andy,
yeah, I’m based in Melbourne, I will check it out. Have you bought from this website before?
B
No I am not with Evok3d. I am an engineer based in Melbourne. Have 3 UP plus printers for prototyping and producing end use parts. The UP plus 2 would be a good buy at the moment. There are heaps of tricks and mods you can make to make them print better. I have added an enclosure and temperature controller which helps.
I have tried a couple of other printers and found that the UP plus is easy to use and gives reasonable quality prints. Any supplier is fine:
I think that the 3dprintingsystems it the distributor for the ANZ region and services most of the other suppliers.
Cheers
Scott
Be sure to check out the Buyers Guide as well: Best 3D Printer Guide 2023 | Hubs
Thanks Scott. I’m looking to start off and just get something printed off here via the Hub, next step will be to purchase a Printer. Thank you for the details that you have provided me so far. Is there a lot of activity on here with regards people requesting Prints from people with Printers? How often would you receive requests to print objects?
Thanks again,
Brian
Hey Simona,
Just checked out that link. thanks for that, its very informative. what Printer do you run with?
Thanks for the useful info
Brian
Quick Details
Brand Name:J GROUP ROBOTICS
Model Number:P0010
Place of Origin:India
Packaging & Delivery
Packaging Details:3D Printer - 1 quantity 3D Printing Filament - 1 quantity Charger - 1 Quantity Warranty Card valid upto six months. Shipping, Duties & Taxes extraDelivery Detail:3 WEEKS
- Print size ( X Y Z ): 420 MM X 720 MM X 420 MM
- The Layer Thickness : 0.05mm to 0.2mm
- Layer Resolution : 50 microns to 250 microns
- Chasis : Aluminum
- Printing Filament : PLA,ABS,NYLON,PVA,PP,TGLASE,WOOD,STONE,CARBON FIBER & MORE
- Filament Diameter: 1.75mm
- Nozzle Diameter: 0.5mm - 0.3mm all metal
- Machine Dimensions: 650 mm x 480 mm x 850mm
- Shipping box dimensions : 700 mm x 580 mm x 570 mm
- Machine weight : 16kg
- Shipping box weight : 19 kg
- Maximum Print speed : 100 mm/s
- Recommended Print speed: 70 mm/s.
- Print Plate Size : 250mm x 250mm.
- Print Plate (Build Platform) : Heated bed Glass.
- AC Input: 100-240 Volts , 50-60 Hz
- No.of Extruders: 2
- Power Requirements: 24 volts , 14.5 Amp
- Connectivity (Interface): Usb, SD card
- Electronics: Arduino 2560 sheild with LCD & SD Card holder
- Operational Environment (recommended) : 15-32 degree celcius
- 3D printing Software : Printware
- CAD Input data file format supported : .Stl, .obj
- Client Operating System : Windows, Linux, Mac
- Print in dual color : Yes
- Warranty : One year - Limited Warranty
- Price - 9500$ USD
- Contact: sales@jgrouprobotics.com
aurarum.com.au
Based in Ringwood, they sell a few prints which are all quite great. They also have incredibly cheap filament.
You might want to consider ordering a cheap printer internationally and dealing with the price. Considering the small range of printers available in oz compared to the US, it is probably cheaper to by one and then ship it.
I would recommend a M3D Micro, as from first hand experience it is an excellent printer. Plus, for $399 (and about $100 shipping) you get 50 microns resolution.
There is also a Printrbot simple, which is pretty cheap too…
Anyway, if you don’t mind paying bit extra for shipping my advice it to get a printer internationally, as overall you can probably get a better printer for a cheaper price.
