I would be pretty unhappy with that coming off a printer also. I see three problems, 1. blobs, 2. layers that are not smooth, 3. diagonal lines showing.
You said you set the fans to 100%, if this is not the default, go back to the default settings.
You said you are printing on High (fine resolution?) Try the print on medium resolution, it is more forgiving and see if you get better results.
Someone else asked how many shell layers you are using, I would use 2+ for this. Again, there should be default settings for shells (bottom, top, sides) and fill percent.
The diagonal lines are on the vertical surfaces so not from infill. Are there internal walls in the model that are showing? It could be a combination of that an thin walls. If so, wrap the file with something like Netfabb to eliminated internal walls.
The “unevenness” of the layers could be due to cooling too fast if you set the fan speed higher than default for the profile.
You said you have printed lots of PLA at school with no problems. Same or different model/brand machine? Have you tried this model at school? It might be worth doing a comparison with the same file and settings on different printers and see if it is the machine, slicer, or model.
I would stick with the default setting and slicer.
Is this PLA, if so is it “fresh”? Could it have absorbed moisture?
Those little blobs almost seem like they are from garbage collecting on the extruder tip and building up until it got knocked off and attached to the print.
This is all speculation without seeing things in person but I would make sure you are using default settings, the Makerbot slicer, good material and that firmware and software are up to date. If you are not using Makerbot filament (I know, very expensive) that is another variable to consider as sometimes recommended temps are different.
In summary, I would stick with the default profile settings for whatever material you are using and make sure you are slicing with Makerware at this point to reduce variables. You might also want to do a comparison test and/or a different model such as a simple cube
Has the printer ever printed nicely?
