Hello I have a felix 3 and yesterday i treedt printing something but the result was not what i expected. The layers where really showing and some overhangs were not good. It cant be the model or the slicer because i used the same gcode i have used a lot of time without problems. And prints right before the problem occured don’t have it. The only thing i changed was that i lubricated the liniear bearings. After i noticed the problem i tightend the belts a bit but no result. I hope someone can help me. Tibo
Zapaer
Sounds like a bed leveling issue. Re-calibrate the z-axis (nozzle to bed distance).
Hello Thanks for the reply. The bed levling is not the problem sadly enough. Part if the problem was that the nozzle was cloged a bit witch caused the plastic to not extrude constantly. Also for some reason the layer height in the gcode changed i don’t know how and i don’t even know how to do it. Now the problem is kind of solved but i now have more curl up at the overhangs.
Zapaer
You can change the layer height using any slicer like Cura, Simplify 3D or Slic3r and or Repetier Host.
