MB3D
Hi everyone !
I’m currently building a new enclosure for my 3d printer and would love to have lasercutted panels for this purpose. I need a total of four panels with maximum measurements of 55x60cm. There are also some smaller sheets required. The prefered material is PMMA (Plexiglass), but other materials would be OK too.
Otherwise I could also mill those panels with my workshop tools, however large PMMA sheets seem to be fairly expensive, does anyone know a good website/store to order sheets in the size-range mentioned above?
Preferably in Germany or at least the EU.
Marius Breuer
himarius
i have a laser cutter and i could cut it for you
i need to know the thickness of the material and the color so i could ask forprice to my supplier
the only problem is that i’m in italy should be expensive to ship to germany
MB3D
Hi Antonio, Thanks for your offer. The material thickness should be 3 or 4 mm if it’s a little bit thicker or thinners that’s fine too. If possible the panels should be clear, but if colored material is cheaper, that’s worth a thought. I’m painting the panels anyways so color doesn’t matter that much, just a few clear windows should be in there. Shipment within Europe isn’t that expensive so I’m fine with that. I’ll contact you later the day with more details. Cheers, Marius Breuer
ok my emai is antonio@bencini.it
MB3D
I’ll contact you via your hub, if that’s fine for you. Please send me a link to your hub. Cheers, Marius Breuer
