Hi.
Is there no way that a “JOG” option can be added to the software?
In principle it should be simple enough.
Add a “JOG” Icon. in that dialogue box, you would display your X. Y. Z. Triad, click on an axis and using the mouse wheel, jog that drive in + or -.
Reasoning:
1; When there is a power problem, the build is up against the nozzle and can cause damage to the extruder head when trying to remove the failed build.
2: Added to that to manually check homing positions by means of jogging.
I have a home problem where the nozzle tip does not locate on the steel button, to try and trouble shoot while active homing is running is very difficult.
Regards
Myer
