Hi everyone!
A month ago I bought the 3d printer Anycubic Kossel Linear on Amazon. I correctly assembled the printer and it works, but I have some problems during the installation process. Here are some photos of the instructions, in which are written that I have to open the file marlin.ino or marlin.pde with Arduino software but I didn’t manage to find this file, I found only marlin.h. If I try to follow the instruction shown in figure 35, the uploading failed (the printer is connected to my computer). I also include a photo of the fail uploading from my computer.
Thank you for the attention, I hope someone can help me.
Ismaele, Italy
Io ho il modello plus da alcuni giorni e sono riuscito ad inviare il firmware senza problemi.
Hai impostato correttamente la velocità di connessione?
ruevs
Try to download the Marlin firmware from here:
Or the older versions from here:
The file you need to open in the Arduino IDE is “Anycubic_Kossel.ino” it is located in:
“Kossel files_20161116.rar\Eng-Kossel files 20161116\Firmware\For Linear and Pulley\”
or
“Firmware for linear and pulley-with hotbed_20161126.rar\Firmware for linear and pulley-with hotbed\For linear and pulley-with hotbed\Anycubic_Kossel\”
or
“Updated Marlin for KOSSEL PULLEYLINEARPLUS_20170110\Anycubic_kossel_updated Marlin_for Aruino 1.6.8.zip\Anycubic_kossel\Anycubic_kossel\”
Alternatively you can try my Repetier firmware for the Anycubic Kossel Linear here:
https://github.com/ruevs/repetier\_anycubic\_kossel
Repetier firmware is better for delta printers since it is faster (lower CPU load) and allows more time for the more complicated geometry calculations involved which results in smoother moves.
Follow the instructions to install and configure.
please upload for me firmware repetier for anycubic plus trigorilla board
ruevs
You can use the one above. Just read the description on how to change the height, radius and arm length. You can find those in the Marlin that Anycubic provide.
I tried but did not succeed. if someone can repetier sends me to anycubic Plus
Geeps
7
Does your Repetier firmware you mention above have the heated bed control included? I’m very new to 3D printing and having finished building my Anycubic Plus with out the heated bed but am battling with getting good results with regarding quality of my prints they are correct in size but seems to be under extruded and no matter what I change it either gets worse or jams. So now wondering if I shouldn’t try Repetier. Why I ask about the heated bed is if I’m going to have to recalibrate the printer then I should install the heated bed
ruevs
8
It does not. However you can upload my configuration.h to the Repetier download page an configure the heated bed in the web interface. Then download it.
