When I print an object with infill, I noticed that some of the perpendicular lines aren’t connecting. Could anyone offer a reason as to why this is happening?
TypeR
What are your print-settings.
Do you use a different speed for infill?
Do you use a different flowrate for infill?
MaddieG
Hi there,
This happens because infill is printed at a higher speed than the rest of the model, and your temperature isn’t set high enough to allow the correct amount of plastic to be extruded. I would recommend either reducing your overall speed, or increasing your extruder temp by 5c and see if that helps.
Best,
Maddie - 3D Hubs
