Suddenly my printer is not reporting the correct Extruder temp, at room temp it says the extruder is at 210 deg C.
I have measured the thermister and resistance is 95k Ohms.
There was an incident at the time this started with the extruder, when I thought I saw a spark, which damaged the previous sensor.
I have tried moving the temp sensor to another port, but the extruder motor stops working.
I suspect something is wrong with the Arduino board, as I have already replaced the Ramps board which did not solve the problem.
Regrads
Kevin
Hey @Amiga1200,
What printer are you using?
Looks like a malfunction of the motherboard!
