3dpGeek
Is anyone else having a problem with the Hub perks? Every time I try the Proto-Pasta code it either gives me a code that is invalid or throws up an error saying it can not generate a code.
Anyone else having this problem?
@Filemon
Asad3D
Hey @3dpGeek, sorry to hear you’re having problems with the Hub perks. Is it still not working? I can try to look into this, but if the problem still persists, I would also suggest contacting customer support.
Yes I am still having the problem. I emailed Customer Support back on September 23 about the problem and never heard back.
Hi Chris (@3dpGeek), that doesn’t sound good. Will check it out
@3dpGeek Should be fixed, can you confirm?
You are the best! Its working fine! Thank you very much!
