I like to print something that is 201 x 201 x 10 mm. The file is uploaded, I can select the material and the distance. The list with possible hubs includes also hubs that cannot print this size.
The solution seems to be to select a specific printer. I had to check the printsize for every type of printer. Is there another solution?
Hey @bart_38 the Hubs should be automatically filtered based on their printer build sizes. This is determined by the file you have. Based on these dimensions most common 3D printers should be able to print your design (of course there might be issues with the design that prevent it being printed well on the small machines - that’s why you might be having the confusion!
I see you have already placed an order so let’s hope it all goes well :wink:
Thx, unfortunately I did not find the right hub. By the first I had to resize my design, the second increased the price with 100%. Let’s hope the third will be able to print it. :slight_smile:
