With the 3d printer market rapidly changing, new filaments coming out every week , a lot of 3Dprinter users are still stuck with small print beds, fine for little models but what if you want to take the next step and make something large in 1 piece ? have you had to turn any work down as you just do not have the capacity to make it on your printer?
There is a resolution!
The new wanhao D5s by technologyoutlet is a steel frame printer capable of printing down to 20 microns with a build size of 290 x 190 x 590
The Duplicator 5s is designed with Arduino© microcontroller with a custom motor shield, a circular dial touch controller/LCD combo, and stepper motors has the capability to run printer at high speeds in excess of 300mm/s.
This machine is Fast, Accurate large and importantly reliable with a 37L build volume it is difficult to match with a price of Just 1595GBP, in stock in the UK for next day shipment. For more information or to see a video of the machine printing please check out Technology Outlet | 3D Printer UK Retailer | Free UK Delivery
Filemon
Have you seen the Delta Printers?
Hi there, are you able to post any tall prints you have created using the Wanhao D5? Thanks
please take a look at the picture on on our website
thanks
Quick Details
Brand Name:J GROUP ROBOTICS
Model Number:P0010
Place of Origin:India
Packaging & Delivery
Packaging Details:3D Printer - 1 quantity 3D Printing Filament - 1 quantity Charger - 1 Quantity Warranty Card valid upto six months. Shipping, Duties & Taxes extraDelivery Detail:3 WEEKS
- Print size ( X Y Z ): 420 MM X 720 MM X 420 MM
- The Layer Thickness : 0.05mm to 0.2mm
- Layer Resolution : 50 microns to 250 microns
- Chasis : Aluminum
- Printing Filament : PLA,ABS,NYLON,PVA,PP,TGLASE,WOOD,STONE,CARBON FIBER & MORE
- Filament Diameter: 1.75mm
- Nozzle Diameter: 0.5mm - 0.3mm all metal
- Machine Dimensions: 650 mm x 480 mm x 850mm
- Shipping box dimensions : 700 mm x 580 mm x 570 mm
- Machine weight : 16kg
- Shipping box weight : 19 kg
- Maximum Print speed : 100 mm/s
- Recommended Print speed: 70 mm/s.
- Print Plate Size : 250mm x 250mm.
- Print Plate (Build Platform) : Heated bed Glass.
- AC Input: 100-240 Volts , 50-60 Hz
- No.of Extruders: 2
- Power Requirements: 24 volts , 14.5 Amp
- Connectivity (Interface): Usb, SD card
- Electronics: Arduino 2560 sheild with LCD & SD Card holder
- Operational Environment (recommended) : 15-32 degree celcius
- 3D printing Software : Printware
- CAD Input data file format supported : .Stl, .obj
- Client Operating System : Windows, Linux, Mac
- Print in dual color : Yes
- Warranty : One year - Limited Warranty
- Price - 9500$ USD
- Contact: sales@jgrouprobotics.com
