hello, i am new in 3d printed world. i have problem to choose the right filament for my project. i want to make 3d printed clutch/bag. any idea which filament will suit my project?
Thank you
Hello, do you need the flexible filament or just normal plastic filament?
hi flyrobot, because i am new, i think normal plastic filament is better right? they also have many colour options.
Its depend on object you will print. Plastic filaments have different characteristic. If you new in 3d printer, i suggest try PLA.
Being new your best bet is mostly likely PLA because its, in my opinion, the easiest to print. PLA is a stiff material though so if you want a flexible print I would recommend Ninjaflex if you want it to be rubber like, Semiflex if you want it to be a little stiffer, or Tualman PCTPE if you want a rigid print but also want live hinges. In my opinion from hardest to print to easiest it goes, Ninjaflex, Semiflex, Tualman.
Suggest you try PLA filament
