​I just purchased an Anet A6 printer from GearBest.
During assembly I see that the thermistor on the underside
of the hotbed is not connected to anything.
I assume it needs to be wired directly to the center two
pins of the connector, but what do I need to do to protect
the wiring from the heat, and fastening the wire to the board?
Please notice the bed cables are 4. Its “plug and play” look references and manuals… You will see… 2 cables in the plug , red and black for bed. The other 2 in the connector are for termistor
Because the leads were not trimmed, it made me believe they were not connected.
Upon closer examination, and checking connectivity, I found out they were indeed connected.
Sorry for the false alarm.
muhahahah… ;p before alarm check twice, and as I said, manuals. There exist for something (like garanty, for clean asses :’) ) luky its PDF :wink:
