So a hollowed out cube would appear cheaper on a hub.
I have had many a customer send me hollowed items.
I then have to explain how supports work, so the the print would be printable.
I then add the cost of the supports, and the removal of the supports, and the savings are not much, and the print will not be as nice.
So lets say you take a cube, and hallow it out.
It is possible my slicer will not see it as hollow, because there is not outside area that matches the inside area. In this case, it gets infilled.
Or-When I load it into my slicer, if it is not open, I will have to print supports inside it, which I cannot remove. The supports become, in effect, infill,- requiring additional time and materials for printing. SO I increase the cost.
Sometimes I get models that have been hallowed, and have a hole in them, or have otherwise been hallowed out in parts. In some of those cases, I can print the supports, but can’t get in there to remove them, so the supports are just up in there, and the print is weak, and the customer has created a situation where the print will not be so good, and will be weak.
So you are much better off not hollowing it out. You will likely not save much, and the print will be much better.
