hi i wonder if you can give me some advice I’m looking for someone to make make a stl file for me it is a belt cutter i use for my job i had one one before but lost the files i only have a few pics of the cutter i does not need to be a exact duplicate
Hi @tonytwistuk, at the moment the checkout flow is optimized for 3D printing only, but you can definitely find a Hub that can help with 3D modeling or 3D scanning services, for example.
The best way to find a Hub for modeling is to use the More Filters button under the location field, and check ‘Can help with 3D Modeling’. This will result in a list of Hubs in your area that can help with the design. Feel free to select a hub from the list, then click ‘view Hub’ in the pop up, then contact / enquiry with the hub on the hub profile page. Ta-daaa! And that should do it.
Hope this helps! Let me know if you need help in identifying a Hub for your design. Cheers!
Hi Tony
I’ve only just found the Milton Keynes tag. I’m based not too far away in Welwyn Garden City. If this is something you’re still looking for help with, I could possibly help out. I assume it’s a project long finished and gone now though. Please do keep us in mind for future prototyping though.
Best regards
Adam
