I know the whole point of 3dhubs is to connect me to such services, but there are many variables that I’m not sure about. Eg. what printing process should I choose, what material should I choose, what printer model should I choose.
I need help in finding a suitable 3D printing service to print 3D models/dental arches (sample attached). These models will be used to create invisible aligners by using a thermoforming process (ie. heating and suction of a plastic sheet over the model similar to this process
AD106_Jaw_00_Lower.stl (13 MB)
Additional information:
The model should not shrink or expand during or after thermoforming.
Hi there !
depending on your requirement for detail I would suggest to go with SLS/SLM or SLA/DLP printers, like the Form 1+.
SLS/SLM works by having a box of powder, which gets molten at specific spots with a laser. This allows for high accuracy, but maybe isn’t as heatresistant as it needs to be. SLM uses plastics, of which the most common is Nylon, also called PA.
Nylon has a relatively low heat resistance and will most likely deform.
SLS uses metal powders, those will resist the temperature, but are very expensive, the average is 10-30€ / cm³, just for the printed material.
SLA/DLP printers use resin, which is cured with a laser. This also gives high details, maybe a little bit less compared to SLS/SLM, but it would be surely enough. I have no idea on how heat resistant those resin prints are, as heat isn’t used during the printing.
Lastly you will have heard about FFF/FDM printers, those extrude plastics through a nozzle. The print quality can differ a lot and in general the quality is much below what SLA/DLP and SLS/SLM can produce.
Layerheights of 0,1-0,25mm are common for FFF/FDM machines. My printer can handle up to 0,025mm layer height (theoretically even less, but that may suffer nasty surface artifacts).
As these machines melt the plastics, you can imagine, that the heat resistance is fairly low, and that’s partially true.
There are tons of materials to choose from for FFF/FDM printers, the most common, which is PLA, can deform at 60°C, so it won’t fit your needs.
The second in line is ABS, which is stable up to 120°C, but it can shrink during the printing, which may mean, that a model, that is designed with a 60mm width will print out with a 57mm width.
Therefore ABS is also a material to avoid.
To shorten the comparison I will skip to the materials that will work for this application:
BluPrint by Taulman3d (i offer it upon demand, I don’t have it in stock)
Polycarbonate
Tritan by Taulman3d
T-Glase / XT / PET / PETG by Taulman3d / Colorfabb / random brands (if the heat doesn’t exceed 70°C)
There may be more materials that would suit your needs, but these are the ones, that I know of. I would recommend XT as it’s fairly cheap in price, while providing a good print quality.
If XT wouldn’t work for this application I would recommend BluPrint as it’s reasonably strong and can be used in temperatures of up to 130°C.
Polycarbonate is very difficult to print and there’s barely any hub, that will offer Polycarbonate (same goes with Tritan).
Even though I would like to take this challenge, I think, that the first four printing methods will give you the best results. Especially because FFF/FDM printers are limited to certain wall thicknesses (which are equivalent to the nozzle diameter), these methods won’t be able to produce accurate thin walls, like the ones between the front teeth.
If you are interested anyways you can contact me via my hub at:
www.3dhubs.com/siegen/hubs/marius
I hope this helps you out, it would be nice, to hear from you about what method you finally chose and maybe you could even upload a picture of the print.
Marius Breuer
Thanks Marius for the feedback. For each job, there will be 30 models to print (similar to the ones I attached in the original post). 15 for upper jaw and 15 for lower. Each is slightly different from the other.
Which printer and material is suitable to print all 30 models within $500 ?
I can’t tell you the pricing of SLS/SLM or SLA/DLP printers. Each hub is individual in it’s pricing, check out your locals!
FFF/FDM printers will most likely be able to print this for <500$. If you want, you can start an enquiry at my hub, I’ve taken a closer look at the model and I might be able to get the job done, but you’d have to take a closer look at the preview.
I can do some testing, if you’re interested. Do you have a deadline for this project ?
Also I need to know, what maximum temperature the print has to resist.
If you want to contact me, you can start an enquiry (for free of course) on my hub, the link to my hub is seen above.
Marius Breuer
hi
you can try DWS
i have one machine for print dental model
and i have a scanner 3d solutionix for reverse the orthodontic mold
ciao
Hi
Our printer can do this job for you and is specifically designed for this kind of work. The materials we use are suitable for the aligners and I have attached a picture of aligners made from our machine. You can find our hub by following the link.
https://www.3dhubs.com/leicester/hubs/irongiant3d
Hi Wasi,
This is Talha from Xplorer 3D, Karachi Pakistan. We’d be glad to be a part of your project! Feel free to getback to us any time at .
Happy 3D Printing!
Team Pakistan
@Xplorer 3D
Thanks Irongiant for the feedback but your prices don’t fit into our budget
Hi Talha, thanks for your input. Just a heads up I moderated the phone number out - moving forward, would you please stick to using a link to your Hub only as means of contact? Cheers
That’s no problem, hope you find what you’re looking for.
All the best.
@wasimohsin Let us know if you’ve found any suitable solutions :wink:
Hello irongiant3d
do you sell 3d printers for orthodontic?
