Miek
I’m studying Interior Design, and for my graduation project I would like to print a part of the interior. Normally I still make my ‘maquettes’ (models) by hand, but with this project It would take me too long.
That’s why I would like to now if:
- it is possible to have my model 3D printed
- who would like to take this challenge
As you can see (attached), the model is a big net(work) of tiny squares (scale 1:50 each square will be 0,3x0,3mm). The total length of the model is 45cm, the total width 5cm and the hight 6cm.
The thickness of the net? As little as possible
… 1,0mm?
Is there someone in (or nearby) Antwerp who can help me with this? Or who can give me some advice?
Thanks in advance!
BR,
Mieke
Hoi Mieke,
De vierkantjes van 0,3x0,3 gaan moeilijk worden om te printen vrees ik, de meeste printers zijn niet zo nauwkeurig…
Ik heb zelf een printer die de lengte van 45cm wel aankan maar het model zal sowieso niet in 1 geheel kunnen geprint worden door de opstaande kant. Om het raster te behouden moeten de kanten op de glasplaat liggen en achteraf aan elkaar gezet worden. Voor de dikte is 0,5mm wel mogelijk. Heb je een stl bestand?
Contacteer me even op … en dan bekijken we wat er mogelijk is, ik wil de uitdaging wel aangaan
Grtz,
Kevin.
MB3D
Hi Miek,
why don’t you use a mesh, and bend it at the desired edges ?
This would be clearly possible and is a very cheap solution. The added blocks in the model could be 3d printed and glued on the mesh. You can get metal mesh with any hole size and wire thickness at amazon or other online resellers.
The blocks can be printed very cheaply and out of any material (except flexible and nylon), to glue the blocks.
To connect the edges of the mesh, you can either use glue or weld the mesh together.
Marius
Hi Mieke,
You’ll have to look for someone with a resin or Laser sintering printer for this. FDM (Filament Deposit Method) printers are probably not going to be able to handle a mesh structure like that. FDM printers work by melting then squeezing molten plastic (ABS or PLA or…) out of a nozzle much like an inkjet printer would do with ink or a baker with whipped cream on a cake. Those nozzles are usually 0.3 to 0.5 mm but the plastic deforms a bit right after it’s been squeezed out and settles, this causes little deformations (called warping). So if your mesh is going to have to be 1mm that would mean 2 lines of deposited plastic filament. You can bet that is going to warp, and would result in a messy looking mesh. You may also want to think about dividing up the model into pieces that you can glue together afterwards. Most printers handle volumes around 15-25cm³.
There are people with laser sintering printers (your best option imho.) on 3D hubs who could help you with this. Resin printers might also be able to tackle the job, but their print volumes are usually smaller then MDF (more in the range of 10cm³).
1st thing you need to do, is to divide up the model into components that can be afterwards be glued together. And export those components into STL files. Be sure the shapes you export are solids. (closed volumes, where every side has a face facing inward and a face facing outward. See: http://en.wikipedia.org/wiki/Constructive\_solid\_geometry). Try to divide up the model into pieces that can be built bottom-up while being horizontal as much as possible. (ex.: for the mesh, make each side of your structure a separate shape that can be down flat, with as little sticking upwards as possible). Except for Resin printers, most 3D printers build bottom-up, stacking layers. Resin printers often print upside-down, pushing each layer out with the next one forming. Keep that in mind when you divide your model into printable pieces. You can also check your .stl files for errors with tools like meshlab to check whether they will be interpreted right by the printers. Work with whoever you choose to help you build this, they will surely know what tools work best with their printer and how to use it.
I hope this helps you along a bit.
Success with your graduation project!
Kind Regards
Bart
Hey Miek,
ik vrees dat je de grenzen van 3D printen overschrijdt met je wensen qua grootte (of in dit geval de kleinte).
0,3mm is echt klein.
* dmv FDM zie ik dit niet goed komen. Je mesh en features zijn té klein.
* SLS zou net kunnen voor de 1mm structuren en is redelijk goedkoop (meer info: Additive Manufacturing Materials at Materialise)
* SL (of DLP) zou kunnen, maar de meeste hobby-isiten hebben kleine printers en gaan die 450mm niet kunnen of het moest opgedeeld zijn. (Meer info: Additive Manufacturing Materials at Materialise EN High-Detail Resin 3D Printing Service | i.materialise)
Waar ik zou naar kijken is laser snijden, bvb in MDF of plastics voor de mesh (meer info: Uw partner voor het bewerken van kunststoffen - Imatex Plastics) in combinatie met kleine SL onderdeeltjes.
Een alternatief is chemical etching, kan zeer fijne mesh en features opleveren, maar met al het extra plooiwerk gaat het onbetaalbaar zijn.
De beperkingen zijn gewoon de kleine details en fijne structuren.
Als ik een mesh zou maken, neem dan 1,5mm, dit is dan perfect te maken in SLS en redelijk goedkoop (http://i.materialise.com/materials/polyamide)
De balkjes en features van 0,3x… bestel gewoon een test onderdeel bij High-Detail Resin 3D Printing Service | i.materialise
Ik ben productontwikkelaar van beroep, moest je nog vragen hebben of files die ik evt moet reviewen… geef me dan seintje.
Btw, ik ben van Ranst, dus dichtbij Antwerpen.
Hey Kevin, cheers for the input! I just wanted to give you a heads up that I moderated out your email. Moving forward, can you please use a link to your Hub profile as means of contact? Thanks
3DKEV
7
Hoi Miek,
Ik heb 15 jaar als Maquette bouwer gewerkt voor dat ik de 3D wereld in ging.
In antwoord op Bramsky zal ik ook voor chemical etching gaan.
Er zit een goed bedrijf in Scotland, de etchings kunnen per post worden verstuurd.
Het is niet duur, en je kunt kiezen uit verschillende metalen, RVS, Nickelsilver, messing, in diktes van 0.1 tot 2 MM (is te dik voor dit ontwerp)
Je hebt wel een DXF/DWG tekening nodig.
Indien nodig kan ik die voor je omzetten.
Groetjes Kevin.
