Hi , I have a anet a8 3d printer. The heated bed temmperature is showing 106degrees even when the wires are not connected to the heated bed. The thermistor is working fine. Because of this problem , i am not able to print abs . please help
Have you found a solution? I believe I have the same problem except the temperature reads 80c. I’m guessing something is shorting on the main board, but everything looks good to me.
