Technical parameters:
1.Integrated SD card with LCD monitor display.
2.The Layer Thickness: 0.05-0.4mm
3.Layer Resolution: 50 microns
4.Printing Filament: PLA & ABS. Heatbed Required for ABS.
5.Technology: Fused Deposition Molding (FDM).
6.Construction based on parallel arm (delta).
7.Machine dimensions: height:600 mm width:320 mm length:320 mm 4, the total weight: 10 kg (including packaging)
8.Outer frame: imported aluminum, steel (laser precision cutting)
9.Extruder:remotely and high-speed extrusion machine
10.The print head material: copper, aluminum, polyether ether ketone material forming
11.Nozzle diameter: 0.4 mm (E3D-V6) Nozzle temperature: 280℃(max)
12.Filament diameter: 1.75mm
13.Nozzle number: single nozzle
14.Data format: STL
15.Software: Repetier host
16.Print size(X,Y,Z): 160×160×230mm
17.Power input: AC110-220 - v
18.The power supply output: DC 12 v 7 a
19.Print plate: high borosilicate glass 180 mm in diameter
20.Synchronous belt wheel / 16 teeth, belt GT2
21.Upgradable to heatbed.
http://www.reprapmall.com/index.php?route=product/product&path=24&product\_id=114
sales@reprapmall.com
Looks awesome. I have added this to your previous post
