I have been experimenting with my Flashforge Finder on accuracy tests and calibration tests and have found that the prints have a offset of .2 mm on both x and y axis (smaller), although the z axis performs fine. I have used multiple 3d printers and have found that for this problem you would simply raise or lower the the steps/mm for the axis desired, for me usually running on Repetier Host. Although on Flashforge’s Control platform, they do not offer that setting, even in advanced settings. Please send input and thank you for your time, In the photo that portion of the calibration test is supposed to be 7mm instead it is ~6.8mm.
Sorry, I forgot to add the photo.
adjust your extrusion multiplier
Im sorry, how exactly do you do that, because i have never heard of that
It says the thread is no longer available.
