Novice printer here, looking for help with my new Flashforge Finder. I am trying to create a large square game board by first making four smaller squares. After printing the four (identical) boards I discovered that they formed a gap when placed together and determined that my “square” is actually between 0.5-3 degrees off at each corner, forming slightly skewed parallelograms. I am positive that my 3D model is a perfect square so I suspect something might be misaligned on the printer. Any ideas on how to check/fix this issue?
Thanks!
Before I can help you with your question, could you tell me what kind of material you are printing? ABS, PLA? Do you have a heated build plate? What temperature is your extruder and build plate set to? Are you printing to glass? Do you use any method to help with bed adhesion?
Hard to diagnose. Pictures would help. I would try printing at half speed and see if anything changes. This would help narrow down whether your motor/driver is missing steps or you axis are actually out of alignment or something else.
-Jesse
Thanks! Flashforge Finder only uses PLA and does not have a heated build plate. Extruder set to 220. Struggled with bed adhesion at first, removed the proprietary bluetak and have found that 3M blue printers tape plus a raft prevents the curling I first encountered. I am attaching a photo that shows what should be four perfect squares aligned against a carpenters square and each other. Your should be able to see the gaps formed.
Thoughts on what could cause this and how I might fix it? Thank you again.
Thanks! I provided additional information on the comment below and attached a photo showing four squares that are actually (very slightly) four parallelograms. I appreciate your help.
If the layers line up vertically then it’s unlikely that your motors are losing steps. Are your belts/pulleys/etc and tight and moving freely? I’m not familiar with your specific machine but the most obvious answer would be that your x & y axis are skewed(not totally perpendicular). That should be easy to verify by visual inspection. Also, I would go download some small calibration models off thingivers to test with.
-Jesse
Your cross bars are slightly out of alignment - purely a mechanical issue - drop FF an Email and ask them how to set them straight - I suspect a simple drive adjustment. If the cross bars that the head rides on as it moves left and right, are slightly skewed, the print will be also. Simple mechanical job :slight_smile:
