My 3d-printer just jammed on the left side and I took it apart and put it back together nothing was wrong but when I took a closer look the filament was stuck to the lowest part of the dispenser… How do I fix this??? Pics below
V V V
I tried loading and unloading filament but it only makes the jammed clicking noise… Do I have to buy another dispenser…?
Anssi_1
If the first didnt work. Heat it up and take the nozzle off. And get it to acetone bath (if it was abs)
Anssi_1
Heat it up to 130-140 (abs) 70-80 (pla) celsius and get something to pull it off or push it down. Better if you can get it off.
Heat it up to 150 use like a metal rod same size as the filament and push it thought.
Make sure the whole filament barrel is clean before putting it back together.
Well cold pull can het foreign parts off from the nozzle.
If the part is ABS, heat it up to 240, and as Cokreeate said, push something through that is the size of the hole.
I get this all the time; heat up the nozzle to about 230 and then get a safety pin, heat up the safety pin and then with the heated part stick it in the filament and then wait 5 sec and then pull it out. You need to do this a couple of times but please be careful as this is not safe and do not stick the pin to far down as you do not want to damage the pipe in the nozzle.
Definitely heat up a small pin and press it into the hot end a bit more - I had a similar problem with a flashforge finder and the gap between the extruder gears and hot end.
