My Flash Forge being crazy, every time I go to print from the computer the program flash print tells me that the TF card is full. I need my printer up and running can someone please help me to figure out this problem is very new and has numbness in using printed for a while now most a year. Again that’s only one sending the file to the printer from the computer
I don’t know what it is. But if the file name is too long then it gives error. Shorten the file name and retry it.
Have you tried using a different slicer?
Also try the option of going to the Edit Menu-- and click on Empty Undo-Stack. If the problem still persists then you can try reseting the machine back to its factory defaults(in the Settings menu) through the touch screen interface provided on the machine.
Just use sd card with one file at a time on it.
